need Your EXPERTISE...
I have a savage with the stock .21...
I just put on a 3 piece mugen clutch set, with flywheel., ofna 16t bell and an rb pipe and a motorsaver filter.
Just before i did the above i replaced the piston and sleeve, and broke in properly.
Now here is my question...
When i give it gas the engine high revs and then eventually goes, it doesn't take off like it used to. I'm not running it to rich either that was the first thing i checked.
the bell spins freely, everything seems to fit perfect. it rolls backwards and no hang ups.. Would it have something to do with the slipper clutch. I have no idea what a slipper clutch is I know where it is that about it. Do I have to adjust it, since i went to a bigger bell, if so how do i adjust.
Thanks again...
