I got my unit back from ACE after two and a half weeks, they replaced the yellow module basically all the electronics/receiver except for the servos. And guess what it still is not working correctly! When flying the heli after 3-4 min it I keep having to add left rudder trim toward the end of the flight the trim is pegged all the way to the left I also have a bit of a bounce in the tail.Next the power is not the same since they replaced the module. This heli is crap as far as I am concerned and ACE is truly not sure how to fix them correctly. One more note they sent a set of damaged rotor blades and damaged my body during the repair and I had to call and complain and they sent out a new body, and blades. Now I need to send the unit back for a second time. No way was this unit fully tested this never should have been shipped out this way. One more note I have gone thru the set up with them on the phone two times and it still is not working correctly!
Angelo
