RE: Jett 60 issues
You need to retorque the head using a torque driver. I'd use around 10in/lbs. Use a star pattern to ensure that they are torqued evenly.
It's not uncommon to have the head bolts loosen up after a lean run or two. If it's a new motor you should check them before running the first time and then every gallon or two.
