IJAA- There are two three position switches that can be assigned to rates, but moreover there are eitht flight conditions that can have a specific rate assigned to each for up to 24 total on two surfaces and 16 on the other. Is that enough?
ORIGINAL: tadawson
None of the 2.4G bogosity being in a very crowded band with insane numbers of part-15 (as well as unlicensed) stuff that is of very low quality and questionable spectral purity, not to mention the far more quirky propagation with regard to nulls and shadowing on 2.4G.
- Tim
tadawson- Holly cow... Geek factor levels off the chart! Iam not worthy!!!
Just giving you a hard time... no offence. Seriously though, you could probably adapt a Futaba 50mhz module, you just have to match up the pin outs. By the way, our 2.4 system does not suffer from the woes you describe so eloquently.
Mike
