RE: Screamin Demon / Lickety Split build
Nearly done! Got the covering on, sprayed the tips in Insignia Blue, and will add some neon insets to the tips, and some blue large checkers to the white underside I think. My eyes need all the help they can get.
Only the tank protrudes, everything else is flush. You could fit two radio systems back there. AUW is still projected at 2.75 pounds, but we'll see where I screwed up once all the trim is done and ailerons mounted.
Mebbe test fly Sunday. More likely Tues-Wed.
And BTW, all the parts are on track - plywood parts all cut, balsa being done now. Yeehah!
Mike D aka MJD
MikesRC
