Day 4
Rudder servo and tank mount.
So here are a couple of areas that need a bit of inventive engineering.
First the rudder servo needs a plate made form scrap 1/8" play. i used 1/2" triangle stock to reinforce it and glued ut between the formers, so that the servo arm would be level with the cable tubes. Use 30min epoxy for this.
I need the tank to be centered and supports with enough room for me to get my hands past it to get to the cowel mounting screws. This will make more sense later!!
The mount doubles as a battery tray and will be screwed to the firewall and former with 4/40 screws and T-nuts. that way it can be easily removed for maintenence.
That's enough for today. Its time to grab a cold beer and stare at this beauty for a while..
<input type="hidden" id="gwProxy" /><input type="hidden" id="jsProxy" onclick="jsCall();" />
<input type="hidden" id="gwProxy" /><input type="hidden" onclick="jsCall();" id="jsProxy" />
<input type="hidden" id="gwProxy"></input><input type="hidden" id="jsProxy" onclick="jsCall();" />
