RE: Bubble Jett tank location ques?
Hey there...... thanks for writing.....
Tank location will be fine.
Be prepared with a pair of hemostats to clamp off the fuel feed line after you fill the tank. It will naturally want to flow down hill, and you do not want to flood the engine.
Hyraulic lock is very easy to do with these engines. So as a precaution, pull the engine through by hand a few times before starting to ensure the cylinder is clear of fuel, and remove the fuel line clamp just before starting the engine.
Bob
