RE: New KMP 70
i have the older razorback and if you cut out the front of the cowl a little it will look o.k. all i can say is that it flies awesome but as all fiberglass arf's it show's age way too quickly. it is way overpriced for what you get. but for the guy who doesn't care about scale and just wants to say he has a warbird it is a good flier. this was my second arf to bash and i learned my lesson, build from plans or a kit because in the long run you don't save enough time to overcome the headache's that you will encounter later. the c.g. is waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaayyyyyyyyyyyyyyyyyy yyyyyyyyyyyyyyyyyyyyyy off in the so called instructions, which nearly caused me to loose this bird twice. if you get one make sure it is way nose heavy and you will be right on the mark. jeff
