RE: 1/2A Size Boat Club
Ok Did a little research...there are no more of the little piccos available on e bay but tower hobbys has them for 65 bucks only thing is the ones they have do not come with the pull starter. so you would need to find a tiger drive to start it or find a flywheel to fit it but it is a very good engine..I have the original toki? .05 that came out of my chaos buggy and will try it in what ever hull I wind up using...
Didnt realize it but allready had a couple hulls that look like they fall into this category of hull have a look at them and let me know youre thoughts.... The longer hull is in pretty rough shape I dont know if its salvageable or not again look at the pics and let me know...the shorter hull will be painted and reassembled by this time next week I reinforced the bottom of the abs hull with 3/16 ply epoxied in,added a 1/4 inch transom plate and yes I realize I am probably nuts for this but I did it anyway I hung a K/B 3.5 on the back.. and the hull has been filled with pour foam for extra rigidity as well as flotation.... Ok well Ill be painting this weekend so yalll HAVE FUNNNN
