Question on initail start up on T-Maxx
I read somewhere to use some after run oil BEFORE I start the engine.
My question is, the air filter has a zip strap on it, in the video they pull off the air filter to clean, so should I cut off the tie and leave it off?
On an onboard temp gauge(traxxas) where ahould you mount the read out, and I would guess you put the sensor on a fin closest to the glow plug right? On the inside or outside and HOW do I attach it?
I also bought a throtle return spring, anyone have a hint how and where to install this? TO the shock tower?
I watched the video 2x, and I am reading the book. Is there anything that was found to be a better way of doing ANYTHING.
Geeze I did not even start to break it in and I put on front and rear blue aluminum bumpers and braces, front-back and middle blue aluminum skid plates.
What is a good set of threaded shocks and what are piggy backs? Are they better? Ideas on where to order?
THANK YOU ALL IN ADVANCE, without the input on this board I would have never jumped into nitro.
Mike L.
