ORIGINAL: CHAVAN30
ORIGINAL: Thunderbird93
ORIGINAL: CHAVAN30
great truggy. i have the xst and the only problem i have had is when i hitthe brakes hard, the engine dies. it has it's 1mm gap on the slide, but i dont have something right. it maybe the servo has too much play or something. other than that andthe flywheel coming loose, i have had to do nothing to the truck.
Make sure you have the gap when you set the brakes or else the engine will die.
thats what i meant when i said i have my gap on the slide. its wierd. as long as i give a little brake, no prob. i give a bunch of break and completely stop the truck, it dies. could be a bad plug, too rich, etc.
i will check. right now it is 100 degrees in the shade, so i will wait!!!!!
i am just glad the motor was good. i thought i would have to rebuild it, but the fly wheel nut came loose and made it easy to turn by hand.
any more ideas? i cant figure it out. the engine runs fine(and fast), but if i even touch the brakes, it flames out. wierd!
