Figured I better do this before I forget....
The firewall is now pinned with 1/8" dowel and reinforced
inside with tri-stock, the engine box does not need to be pinned as the whole assebly will be clamped by the monting bolts (stainless threaded rod) that will go from the front right through the firewall.
I also trimmed and replaced the cowel ring and spacer pieces I had cut out earlier to clear the box.
<input type="hidden" id="gwProxy" /><input type="hidden" id="jsProxy" onclick="jsCall();" />
<input type="hidden" id="gwProxy" /><input type="hidden" onclick="jsCall();" id="jsProxy" />
<input type="hidden" id="gwProxy"></input><input type="hidden" id="jsProxy" onclick="jsCall();" />
