RE: top flite p-51 giant scale build
doing better now. just glad to get back home.. I checked the fire wall that had been installed and it has not degrees offset built in.. I don't know how he flew it. just motor offset. going to remove the old firewall and install new one the right way. getting everything sanded is taking awhile. then will start to fiberglass everything. had to take everything off and redrill the wings for new hinges. plugged the old holes. redrilled and add dowel's with epoxy. then redrill for robart hinges. should be solid connections now.
almost as much work as building from scratch. but should be about like new when done. maybe by end of july will have it done and ready to go.
