Originally posted by savagethunder21
is there a diagram on how to install everything?
Pretty simple,
-brass collar on first push all the way to the bearing
-flywheel
-clutch nut
-clutch shoes and springs
-maybe a couple shimms on the clutch nut to make sure the bell does not grind on the flywheel
-clutch bell bearing
-clutch bell and outside bearing
then either put your e-clip on or sinch your screw down!!
Like I said above you might need to do a little adjusting with shimms to line everything up but nothing major.
