RE: Low Hover
You can adjust the linkages on the heli to give your a more positive pitch so you get more lift. The linkage i'm talking about the linkage on the pitch servo. There is a set screw that connect the innner shaft to the pitch slider. You can loosen that up and push the innner shaft up a little so it give your more positive pitch.
Andy
