RE: Spot On 50 Build log.
The right thrust is built into the firewall....I didnt measure it. After a few flights I added washers behind the engine mount to reduce it a little. I think the right thrust provided may be OK for a 4-stroke turning 13" props. Whatever engine you are running you'll have to try it and see if you like it before making any changes.
Hope that helps.
Colin.
