RE: Flair Puppeteer Build
Started on the tail yesterday. Covered the plan in cooking grade grease proof paper and carefully measured and cut andd hand trimmed all the balsa. Pin it well down and I used super glue, medium thickness. Left it a few hours then carefully took out the pins put another layer of GPP on the side already built and built the second directly on top. You then have 2 matching halves. The GPP comes off quite easily and a light sanding gives you a great finish.
