RE: LOOK what arrived today!!! Keecat II
Well glued the tail and elevator on tonight, things to note, place a loop or draw wire into the tail before fitting other wise you will never get it in later, DRY FIT EVERYTHING if you glue it you dont want any supprises, I found the upper elevator to be out of alignment which required a "kick" anti clockwise by slotting the screw holes, use the usual method of a string attached to central points of the body to check alignment
