ORIGINAL: freakingfast
Make sure you put a 1/4'' thick piece of urethane foam rubber
http://www.shopatron.com/product/part_number=513/101.0 under the fuel tank and some pieces around the perimeter down below to keep tank from contacting the top deck. Don't over tighten the tank restraining strap. Don't use ethylene foam for any thing RC(white stuff that electronics are wrapped with) it has poor vibration absorption. A good fuel tank is a Hayes 8 oz. regular, it can take the pressure easy.
http://www.horizonhobby.com/Products...?ProdID=HAY070
I'm curious, is there any reason not to use a Jett or Tettra bladder tank with the YS setup? I wondered if tank pressure is too high and they blow stoppers or something, or are they fine to use as well?
MJD
