RCU Forums - View Single Post - ZN Line Xigris Build Thread
Thread
07-30-2009, 10:03 PM
33
can773
My Feedback: (
1
RE: ZN Line Xigris Build Thread
We are nearly ready to cover.
I do this part a little different maybe than most. What I do at this point is actually glue the hinges in, and then use white covering and gap seal top and bottom prior to covering.
On the ailerons you should also cover the inboard root of the aileron before hinging.
I only took a shot of the stab with the elevator hinged and covered.
Once that is done, you need to figure out where the slot for your elevator pushrod will go. I did this after hinging so that I had the elevator location and travel fixed.
Reply
Like
can773
View Public Profile
Send a private message to can773
Visit can773's homepage!
Find More Posts by can773
View iTrader Profile
