Old 07-31-2009, 08:24 AM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 1 1/4inch spinners
I did not see an option for a NORVEL adapter nut on Mecoa's site.
I have not tried this, but here's a possible solution. Replace the 3mm prop screw with a 3mm stud (just cut the head off a 3mm screw), add your prop, add a washer if desired, use a 3mm threaded standoff from [link=http://www.mcmaster.com/#]McMaster-Carr[/link], add the spinner and retain with a 3mm machine screw. You may need to finagle the lengths a bit, but I think it's doable. 4mm threaded standoffs are also available if you wanted to add a small spinner to the NORVEL .074 . The standoffs are available in several lengths.
andrew
File Type: pdf
Andrew is offline
