Crossed Pull Pull cables?
Crossing the cables makes for an easy exit @ the rear of the fusalage, that is the only reason for doing it. If you do this using swivel ball links on your servo arm, connect one side to the top of the arm & one to the bottom of the arm, this keeps the cables from rubbing each other.
Gil
