RE: NOW BE HONEST....
I think you're right Mike. I'm going to clip some span from it, but it will still be a pretty big wing.
I think I'll finish it like a AMA fast combat plane, which means no balsa sheeting, just limited fiberglass on the surface and seal-lamen or fascal or doculam for covering. Those planes stand up to quite a bit. The key to this plane having any chance at all will be to keep it light.
I made a full depth spar out of 1/8" balsa sheet with a layer of CF cloth on both sides. Kind of a pain to get everything lined back up after making the drastic cuts to pass the spar through the fuselage and into each wing panel. In Gorilla Glue we trust.
Tom, we don nee no steenking CADs..[sm=pirate.gif]
