RE: Need help with Astro Hog crash cause
Thanks to all who have responded with crash cause suggestions.
Since the last incident I have thoroughly examined the wing and cannot find any warps. Secondly, I double and triple checked the balance and it is right on per the plans, i.e. slightly nose heavy at the main spar. Maybe another ounce or two of lead in the nose won't hurt, but I really think the balance is O.K. Thirdly, I replaced the aileron servo and increased the throws to exceed the plan specs. As suggested by Red7fifty, I will range check the plane with the engine running at full or nearly full power. Also, in as much as I experienced the same symptoms as Bob, the next time I attempt take off I will not rotate until the plane has used the entire field at full power and is "screaming" down the runway (LOL). Maybe I didn't have enough speed to take off, but I will definitely rule that in or out the next time I attempt to fly the "Hog".
I am going to give it another try in the next week or two, in the meantime, the KAOS will keep me busy.
All the best to all,
DaveB
