RE: Thunder Tiger 130 Four Stroke
CustomPC the TT F-75s does not have any special lubrication system, it has a breather on the backplate and I had indeed a cam failure because the rear bearing is shielded and couldn't get oil there...I ended making a pinhole on the shield and now it works ok. THe valves are always lubed so there is no problem there.
