prop balancing
Yes, it means that that half of the prop is heavier, not just the hub. You can balance it in several ways. You can spray clear on the respective leading edge of one blade and the trailing edge of the other or remove material from the heavy sides. You can also put screws into the light side of the hub. When properly balanced it should stay in any position you put it in.
Tracy Hill
