RE: Nelson 40 info needed
If it is the F1 what prop should I use?
Is there a way to see which one is it other then the pressure on the case.
The seller posted it as Q40 but I think Q40s are side exhaust please correct me if I am wrong.
What is performance diff. in F1 and FAI
Thank you
Combatpig what is your name? if you fly combat I must have seen you at lone star in the past
