convert chainsaw engine to aircraft engine?!?!
Basically, all you need to do is to make a prop adapter to go from the output shaft of the engine to the prop. From there it depends on how the engine casing is set up for mounting, and throttle linkage. There is an Engine Conversion Subforum in the Engines forum. Browse through it and you'll probably find most of your answers.
