RE: Need Help with SB SPORT V2 BUGGY KIT Build!
It could be that the diffs aren't tight enough, or if there's a slipper clutch, it may be too loose. when checking the diffs, you should be able to hold the outdrives/diff hubss, and you should not be able to spin the gear.
Tim
