Hey Folks,
Tried out the OS max 10 car engine on the lmh and did some test flights but not encouraging. it seems that the engine overheat easily although i tried many different needle sttings and 4 dots 6 dots blade grips.
also, after overnight, i found out that one of the newer longer blade disintegrated itself at the blade root (again!!) i had similar issues with a pair and this is again happening
i changed to the older short baldes but much more rubber- ish feel. i have had no issues with the older blades.
I also saw the web about the multiplex funcopter designed based on the lmh. hopefully they will produce good quality blades when it comes to stock in Uk in Nov. i am waiting for that.
meantimes, i think i give up on the OS max 10 setup and might go back to the force .12 car engine or even earleir os cz .15 engine.
CHeers
Lawrence
