RE: horns
For a typical speed plane with concealed elevator horn, a steel wire torque rod that joins the 2 elevator halves is pretty standard with either a flat strip of steel or brass sheet silver soldered to the axle. The DuBro nylon clevises with the hard steel pins seem good enough to bury in a plane for the duration.
