RE: OPS .65 bench run.. finally!
mjd
good healthy sounds, thats some good rpms, a few more runs, and i would then look at your deck height if its not popping plugs i am curious as to the shape of the combustion bowl, is it single or double dish, and is this engine bushing or needle bearing on big end of the rod? but over all real clean sound, now i gotta run my ops .80 fan engine... unless it does a shaft run it should last for ages, 24k is the upper limit for the bushing rod on the big ops motors
