US 60 With 10X
I got everthing working good, but if I use one of the dual rate switches to control all of the dual rates it couples the flaps with the ailerons. If I keep all of the dual rates on their indepentant
switches this doesn't happen. I have the flight mode switch setup; Up=Crow ,Center=Normal flight , Down=Flaps. I'm using the Mix switch for Elevator/Flap mix. I just don't understand why the flaps mix with the ailerons when I use a single dual rate swith. Thanks for the reply!
Rick
