RE: RS 10 Rockslide questions
Thanks, I wiggled the wires and the car now goes. I still have a severe unbalance in the steering. The car had been crawled a lot in the week I've had it - i have a real rock crawler and was looking at strategies to keep from rollong over, and also to self-right under power whe i did. I may have given it more severe use than what is expected, so loose connections are probably a good place to start. However, the steering problem is in the controller, not the car. I can get it to turn only right instead of only left by moving the switches, and the front is not balanced with the rear. The car did not perform like this when i got it. The controller has not beeen abused in any way, still has good battery voltage on the LCD screen.
