RE: GP Shoestring Power Recommendation
Skyblue, It might be a bit on the heavy side .... but that is because the fuse is all fiberglass and it has that vintage 'chubby' look. Looking at the pics when I ordered it, I thought the fuse was was covered in Monokote because you could see the rib structure but I was amazed when I opened the kit to find that that rib look is molded into the fiberglass ! As far as other 'similar' airplanes from Great Planes being $ 100 cheaper ..... absolutely no way ! There is no other $ 100 airplane (from GP or anybody) that comes close to this in quality. I will have it flying next weekend (Oct 31), I am going to use the recommended Rimfire .46. I will let you know how it goes ... (If you get one, I guarantee you will be impressed with the quality/workmanship). Bob
