RE: MAAAANN NOT AGAIN!!!
hi were the aileron throws checked carefully on the bench in the shop for direction -recomended amount of travel and any servo bindingrod binding that may be taking placedid you forget the servo arm center screw ?did a clevis break or strip check all throw directions before your first flight of the daywere you on the correct computer channel for that planejust stuff that comes to mind and my .02 cents for what it is worth
