Old 11-10-2009, 11:27 PM
  #44
Tko310
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: The RCFW Hellcat Group Build
once i drilled the holes assembled all the pylons abd cut the .125 i.d. alum. tube for the bolt to pass through. Yes they are removable if I didn't metion already. After the pylons were assembled everything was sealed primed and sanded. i then finished the rockets. After everting was dry i assembeled each rocket with its pylons. i labled them all right and left 1,2 and 3. As hard as I try I know they will not all be interchangeable.
I only glued the alum. tube into the pylons there will be some final adjustmet when the plane is complete and I wanted to be able to slide the rockets into the proper alignment. The curvature of the wing is the biggest issue.
ID:	1312050   Click image for larger version
ID:	1312051   Click image for larger version
Tko310 is offline
