ORIGINAL: combatpigg
Would it help to route the fuel line with a loop that is higher than the fuel level?
This might not be ''high-tech'' enough for some guys, but it has worked for me....
I have been thinking about this installation for some time know, I have given it much thought and your idea of routing the fuel line higher than the fuel level is a feasible fix for the flooding problem. The remote needle valve can then be mounted above the inverted motor; the high speed needle would be adjusted from the top of the plane. “High-Tech” or not if it works great.
