ORIGINAL: jereis Help is needed: I'm not being able to put the servos moving the correct direction in a T-Rex Heli Swash Type (3 servos 120º
The "Servo Reverse" option is not enough, to put the three servos moving the correct way for AILE, ELEV and PITC; if AILE is Ok, then PITC is not and if I correct PITC the others became wrong... (as you know, all the three servos move at the same time in order to have a correct move of the Swash Plate, for PITC for example). How can i reverse the direction of one servo only, in this case, without change all the Swash movements? Thank you.
Answered (post1127) and alternative (prior Aurora method) earlierpost 1111.
Regards
Alan T.
