RCU Forums - View Single Post - Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Old 12-01-2009, 03:49 PM
bgw45
Default RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
ORIGINAL: griesel
OK Grandpa T and bgw45 I need to be spoon fed. Could you both please list the rate +/-;
the switch; Adjust to trim setting; both top and bottom on/off settings;and Cut Position.
I used the same switch you used, H. Set the percentage @ -14 on this one. I just set it where it will cut-off.
