ORIGINAL: Scott J
(2) Medusa 36-50-1600 , Castle HV-85 amp esc , 5S1P 2250 mah 30C pack : 2lb. 11oz. or 5S1P 3300 mah 20C pack : 2lb. 15.5oz. ,calcs show 6.5X6.5 prop 26000 at 1000 watts , pitch speed 160 and 90-100 oz. thrust...
...Has anybody ever flown a Dust at 3lb. 6oz. ???
What do you guys think I should go with? Hopefuly Mike will chime in too. I'd like to go with 2 or 3 , so I can leave my Ritewing intact.
Scott
Hi Scott,
Your electric specs probably wont mean much to many in this forum but we will see. My vote is #2 because since #1 is in a RTF wing and should be left there IMO and #3 doesn't have enough extra power for the weight added. At 575 sq in the dust will fly ok at 3lb 6oz but will shine at under 3 lbs. My first Dust probably weighed around 3.5 lbs after 100 flights and many repairs and it flew fine. There are a few Screamin Demons flying well at 3+ lbs and have almost 100 sq in less wing then a Dust. There are also a few 4+ lb big block Demons getting ready to fly.
