Dx6i Dual Aileron & Flaps Setup
What's the best way to set up the DX6i to control a plane with dual aileron servos (1 servo/aileron) and flaps? I've configured the transmitter, receiver, and servos per Spektrum instructions for "Dual Aileron Wing Type" (left aileron servo to AUX 1 port & right aileron servo to AILE port. With this setup the only open ports are GEAR and BATT/BIND on the AR6200 receiver. I connected the flap servos with a Y-harness to the GEAR port, which seems to limit me for other programming. Can I reassign switches with this radio, control the GEAR port on the receiver with the flap switch on the transmitter? Also, I'd like to mix a setup for landing where both ailerons drop 20 degrees or so when the flaps are deployed and am not seeing a way to do this. Anybody have any helpful ideas?
