Progress update and gyro guestion
Thats a great idea davidj,
no doubt on the servo end of the tail rod, you have got rid of the Z bend and placed a rod end, and fitted a ball to the rudder servo horn.
I would like to know if you have ever had a problem with fitting rod ends on to an unthreaded rod, and what method did you use to attach it ( crimpping, or glue or ?????) I would like to do the same to mine but fear that the torgue on the rod during aggressive flight may pull the rod end away from the the rod.
