ORIGINAL: najary
Saving 16.5 gram =(207-196)+(207-196)/2(saving the lateral weight)
I tried to equilibrate the wings weight by using the heavy balsa parts for the light wing and vice versa,
and sand the heavy wing slightly more.
Hi
When you tried to equilibrate the wing weight - I just curious if it's matter if the CG of one wing must be the same as the other wing? I mean that the CG have to be at the same distance from the wing root of each wing.
the build looks great!!!
Daniel, Israel(to) :-)
