RE: Kellogg's AD5 Skyraider Build
SBDdauntless,
Thanks for the response. Just in case you see this first we are one hour behind you.
We had 14" of snow on 12-24 and that led to a white Christmas. A seldom seen thing for Oklahoma.
I think the construction of the wing can be accomplished in several ways. Heck I am building mine from W-10 left to W-10 right in one step and stopping construction at the spar seperation of W-10/W-11. I am going to build the outer panels after that. I did however pin up the left wing panel for allignment purposes as the plan shows. This is where I discovered the fitting question.
I will say this is a great design. The flow of the build is great and I should be sheeting the wing sections soon. Never thought I would like cutting parts so much, but can't wait to start on the horz stab next.
As you can see my little helper is checking out my build job. He really helps me with drilling and holding things. I hope by the time he is 5 we can build him a T-41 Cessna from a Senior Kadit kit as his first gas 80" wingspan war bird.
We did cut a project out for his mom.
