RE: Vailly Aviation Hawker Hurricane Build Thread
I have run out of balsa stringers but they should be here this week. So I decided to build the other fuselage while I still had the crutch stand set up. Man the second one goes a lot faster than the first - all the problem solving done ahead of time! I'm going to start working out the radio install too. I think I'll put the batteries up in the fuse, one pack on each side of the tank box, as close to the bulkhead as possible. Still thinking ignition and it's battery pack a "stuff fit" down between F2 and F3. I do have a set of Brian Taylor's Hurricane plans (70" wing span) and I"ll be incorporating some of his ideas as I go.
Sam
