RE: CDI ignition battery in receiver or direct from battery
Hi Amram,
I normally use the Hyde LR85 mount which weighs ~102g, though you also need a nose ring, which Merle can also supply. This is a great mount, perfectly suited to the CDi engine and is fitted with internal limiters to prevent airframe strike if the engine kicks or goes through a system resonance. Also the whole assembly won't move back when you press your electric starter on the spinner, as does the YS mount, meaning you can have a safe, close gap between spinner and fuselage.
Hope this helps
Keith
