RE: Bobcat 50 notes (nitro Planes)
Marty.......I also mounted the elevator servo in the tail boom. Using a ST .61 for power. Trying to use other tail boom servo for the rudders......a little tricky. Too cold to fly and cold in my shop too, I have cabin fever. I MAY have offset the engine a little, need to check it again. Is it STILL left thrust on a pusher if the prop tips are closer to the wing on left side?
I have not even checked wheels yet, but with an 11" prop, clearance is close.
