RE: Top Flite Taurus Build
One thing I forgot to post when starting the wing construction, is that after I punched the ribs out, like most kits the die cutting leaves a lot to be desired. In this case all of the edges were rather rough and needed to be cleaned up. I paired up each rib with binder clips, and sanded each pair so they matched each other; this only took a few minutes to do. You'd be surprised how much difference there was between the same ribs.
More to come....
FB
