RE: Anderson Power Pole Connectors. Have you had a failure or not?
I've been flying e-power since 92. Everything from gliders to floatplanes to 3D. I have never had a Power Pole come disconnected in flight. They must be firmly seated in the housing with the tip of the contact hooked over the spring. If they seem loose just reshape the bend at the tip of the contact.
Walt
